Пользователей: 490
Аналоги: 298. Даташиты: 135. Инструкции: 1. Новости: 24. Остальное: 1. Профиль пользователя: 8. Форум: 23.
Гостей: 488
Раздел: EDN
EDN №2 2012г
Сообщений MACTEP 04.02.2012 15:20:00 (Просмотров: 5925)
Издательство: Reed Elsevier Properties Inc.
Год выпуска: 2012
Номер: 2
Дата выпуска: 19 Jan
Число страниц: 88
Формат: PDF
Качество: отличное
Язык: Английский
VOICE OF THE ENGINEER
SPECIAL SECTION:
S1.  Special section: 2012 global electronics distribution special
08. EDN online: Join the conversation; Content; Engineering Community
10. EDN.comment: CES is over; it's time to start designing
12. BLDC-fan motor driver employs sensorless sinusoidal architecture
14. Foundation readies S25 PC for launch
16. SLI eliminates the need for touch in MEMS applications
16.  Tiny dc/dc power modules target rugged industrial and avionics environments
18. Microcontrollers target smart metering
18. Intel rolls out 32-nm Atom, preps 22-nm Ivy Bridge
18. Small MEMS modules boost consumer-device sensitivity
18. CAN transceiver isolates signals to 5 kV rms, handles temperatures to 125°C
19. Differential op amp tackles common-mode voltage as high as ±275V
20. Voices: Mark Mitchell: An early interest in computers leads to lifelong ambition
22. Baker's Best: Designing with temperature sensors, part five: 1С temperature sensors
24. Teardown: Vizio VTAB1008 tablet: symbiosis of man and machine
26. Mechatronics in Design: Theory and practice
61 Charger and display noise affects touchscreens, but there are ways to tackle this problem.
66. Analog-circuit-design engineers overcome new challenges with advanced tools and ICs.
73. A properly designed switching regulator can improve the power efficiency of low-power
77. Make an asynchronous clock for VPX-based PCIe systems
78. Use a photoelectric-FET optocoupler as a linear voltage-controlled potentiometer
80. Wireless temperature monitor has data-logging capabilities
82. Simple circuit tests twisted-pair cables
83. Product Roundup: Optoelectronics and Displays
86. Tales from the Cube: The silence of the circuit
Теги:
EDN
