Пользователей: 145
Аналоги: 64. Даташиты: 65. Инструкции: 2. Новости: 3. Остальное: 3. Форум: 8.
Гостей: 143
Раздел: EDN
EDN 3 2013г
Сообщений MACTEP 10.05.2013 14:40:00 (Просмотров: 3990)
Издательство: Reed Elsevier Properties Inc.
Год выпуска: 2013
Номер: 3
Дата выпуска: March
Число страниц: 72
Формат: PDF
Качество: отличное
Язык: Английский
contents March 2013
9.   EDN online: Join the conversation; Content; Engineering community
12. EDN.comment: Pick your favorite contributor; winner gets $5000!
14. Self-contained RF recording system weighs less than 10 lbs
16. Dash-cam video: benefit or distraction?
18. Time-of-flight proximity sensor allows new smartphone-user interactions
18. Motor-control solution simplifies field-oriented-control designs
19. Will 2013 bring tighter power-supply efficiency requirements?
19. Smaller Raspberry Pi costs under $25
20. Voices: Peter Spitzer: Motivated by testing, challenges, and constant learning
22. Signal Integrity: Measuring shadows
24. Connecting Wireless: Another radio, another set of apps
26. Teardown: Cell-phone charger: nice idea done right
28. Mechatronics in Design: Angular velocity is often misstated
31. LED-driving techniques reduce power in LCD TVs
38. Which process and supplier are best for my design?
48. 10 software tips for hardware engineers
EDN 3 201351. Circuit maximizes pulse-width-modulated DAC throughput
52. A circuit for mains synchronization has two separate outputs for each half-period
55. Low-component-count zero-crossing detector is low power
57. DC-DC converter starts up and operates from a single photocell
58. Filter quashes 60-Hz interference
60. Supply Chain: Automotive electronics’ supply-chain impact; Fewer IC suppliers to hold more of 2013 market
63. Product Roundup: Test & Measurement
66. Tales from the Cube: Resolving a simulation complication
Теги:
EDN
