Пользователей: 122
Аналоги: 53. Видео: 1. Галерея: 2. Даташиты: 44. Новости: 9. Остальное: 5. Программы: 1. Производители: 1. Форум: 6.
Гостей: 120
Раздел: Elektor
Elektor №9 2013г
Сообщений MACTEP 09.09.2013 16:20:00 (Просмотров: 4858)
Год: 2013
Месяц: Сентябрь
Номер: 9
Формат:DjVu
Язык: Английский
Elektor - популярный зарубежный журнал по электронике и схемотехнике
ElektorContents
Community
8  Elektor World
     • The CAN Man Came
     • Get the Picture
    Elektor • Draught Version 1.0
     • The Ghost in the Castle
     • From the Pedal to the Saddle
     • From DIY Plotter to JVE CNC
DesignSpark
20 Modular RF Link using Manchester Code (1)
     Here we explore the use of Lynx radio modules for building a reliable
     medium range (>600 ft) over-air data link between two PCs or
     microcontroller systems. This month we kick off with a description of the
     hardware side of things.
Elektor54 Using Libraries
     Neil Gruending continues his get-u-going advice for the DesignSpark
     electronics design software suite. This month he discloses quick ways
     to working with libraries.
Projects
10 Q-Watt Audio Power Amplifier
     ElektorAudio fans, here's a fully analog, very powerful, very low distortion design
     from the famed Elektor Audio Labs. It's based on the LME49881 integrated
     circuit from Texas Instruments, and has complementary bipolar transistors
     in the power output stage.
28 Gnublin Extension Boards
     Thanks to Linux being used as the common abstraction layer, Raspberry
     Pi,  the Elektor Embedded Linux Board and even the new BeagleBone
     Black can use the extension boards described in this article: Relay
     Module, Temperature Module, Display Module, Step Module, and I/O
     Expander.
34 Android Elektor Cardivscope
     Much of the power and versatility of the Elektor Cardioscope is due to the
     clever software developed for the project. This month we describe how the
     PIC24 controller does just what the doctor ordered.
44 From Basic to Python (3)
     In this concluding part of the series we describe how Python can be used
     to provide a communication platform for the ElektorBus. As it turns out,
     the exercise is less complex than when using vintage Basic, with far better
     results though within easy reach.
Labs
58 .Labs Tips & Tricks
     A Cheater's Guide to success at Elektor.Labs and from there on, towards
     publication in the magazine.
Elektor60 90 Degrees and Rising
     Components running hot to the touch can be a real hazard, and in some
     cases there's no way to avoid fitting them to a heatsink as one of our junior
     lab workers discovered the hard way.
Industry
62 News & New Products
     A selection of news items received from the electronics industry/ labs
     and organizations.
Tech the Future
66 Internet @ the Physical Layer
     ElektorConcerns have been raised on the expansion rate of data versus that of
     the hardware structure supporting the Internet, particularly at the IXs. Are
     these concerns justified?
Magazine
70 Retronics:
     Radiometer PHM22 / PHA928a Blood pH / O2 / CO2 Analyzer
     In the 1960s a cartload of equipment and a lot of patience were required
     to perform simple hematology related tests in hospital labs.
     Series Editor: Jan Buiting.
74 Hexadoku
     Elektor's monthly puzzle with an electronics touch.
Elektor76 Gerard's Columns: ConFused
     A column or two from our columnist Gerard Fonte.
82 Next Month in Elektor
     A sneak preview of articles on the Elektor publication schedule.
Теги:
