Пользователей: 105
Аналоги: 37. Даташиты: 34. Инструкции: 3. Новости: 10. Остальное: 5. Производители: 1. Профиль пользователя: 3. Торрент: 1. Форум: 10. Чат: 1.
Гостей: 102
Раздел: Аудио/Видео
Матрица 8х8 от стереоканала
Сообщений MACTEP 14.02.2009 0:30:00 (Просмотров: 29220)
Схема управления матрицей светодиодов 8x8 или 16x16 с управлением от звукового входа воспроизводит случайный рисунок. Вход очень чувствительный.
A A display based on the audio input will not be random. If the left and right channels of a stereo signal are applied to the X and Y inputs of a matrix, it will show the difference in the two signals. If the signal is mono, the display will be a 45 degree line that varies in length with the strength of the signal.
The LM3914 dot/bar graph LED driver is made for this application. The output is a current source so current limiting resistors are not needed. The 1С has 10 outputs but can be expanded to 20 or more. I will design an 8x8 matrix display to show how it works (Figure 1).
The input range is set by the reference voltage. In this case, I set it to one volt, assuming that the input would be line level. The 1/2 input pin is biased u\) I   2 w>lt so ih.it one volt p/p input will not clip. R4 and R6 set the current sink of IC2 at 10 mA. The current sink of IC1 is set at 1 mA and the current gain of the PNP transistors will keep them saturated.
An array of PNP transistors would be nice but the ULN series are all NPN. I found a four transistor PNP array for $6 but with 2N3906s at $.05, I went with singles. Pin 9 of the LM3914 is open for a dot display; you could connect pin 9 to Vcc for a bar display.
My schematic capture program (Eagle) does not do group copy of line drawings so I did not show all the diodes in the matrix.
NUTSandVOLTS   January 2009
Robert Christopher
14
 Re: Матрица 8х8 от стереоканала
Дата регистрации: 07.08.2008
в сети
Заинтересовал. Завтра же побегу в бутик узнать есть ли эти детали.
64 светодиода...
Дата регистрации: 21.01.2009
не в сети
По определению Задорнова, БУТИК - это аббревиатура, которая расшифровуется " Бывшие в Употреблении Товаты Из Китая"...(кстати,подобная схема была опубликована в журнале "Радио" в конце 80-х)Эту же схемку легко расширить до 400 светодиодов. Правда, потребуется не 2, а четыре корпуса микросхем.
не в сети
Проще наверное использовать светодиодные матрицы...Открыть изображение в новом окне
в сети
У нас только бутики, магазинов мало.
Дата регистрации: 09.04.2010
не в сети
Кто то собирал эту схемку? интересно на что она похожа?
не в сети
Примерно вот так она работает...
Дата регистрации: 27.10.2011
не в сети
вот собрал данный девайс и чето он как то не так работает по схеме проверял все вроде правильно ,подскажите что не так вот видео https://www.youtube.com/watch?v=wgFHuq3grls&feature=youtu.be
не в сети
Монтаж проверяй, Напутал ты чето. Почему Q4 открыт без сигнала?
не в сети
сам не пойму ,он исправен я проверял ,да и по схеме все в порядке ,может чето с микрухой.
не в сети
ну так проверь каждую микросхему в отдельности, без матрицы...
