Пользователей: 128
Аналоги: 68. Видео: 1. Даташиты: 43. Инструкции: 1. Новости: 2. Производители: 2. Профиль пользователя: 2. Теги: 1. Форум: 8.
Гостей: 126
Раздел: EDN
EDN 10 2012г
Сообщений MACTEP 24.05.2012 22:50:00 (Просмотров: 14982)
Издательство: Reed Elsevier Properties Inc.
Год выпуска: 2012
Номер: 10
Дата выпуска: May 24
Число страниц: 56
Формат: PDF
Качество: отличное
Язык: Английский
VOICE OF THE ENGINEER
contents
9. EDN online: Join the conversation; Content; Engineering Community
10. EDN.comment: Ignore politics at your peril
12. MIMO PXI vector signal analyzer offers 780-MHz analysis bandwidth
14. Innovative 1С lets you know when lightning will strike
14. Medical wall-mount power supplies provide as much as 15W
15. Compact LCOS pico projector cuts costs
15. Stereo-vision-camera reference design uses Tl's ОМАР
18. Sound-expanding 1С yields audio analog of 3-D for smartphones, tablets
18. Single-chip 10-GbE processor uses massive parallelism
18. Voices: Nathan Seidle: open source, open mind, open for business
20. Baker's Best: EMI problems? Part four: It could be conduction
22. Teardown: Inside the Schick Hydro microcontroller-powered wet razor
24. Mechatronics: Handling time delays
25. USB 3.0: bringing SuperSpeed connectivity to mobile devices
30. Power: a significant challenge in EDA design
39. Understanding noise, ENOB, and effective resolution in ADCs
42. Simple anticipator circuit improves on earlier idea
45. Perform the XOR/XNOR function with a diode bridge and a transistor
45. Use an op amp as a set/reset flip-flop
46. Generate a pulse width that is inversely proportional to the square root of an analog voltage
48. Supply Chain: How the aftermarket and counterfeiting are lirked; Apple to remain media-tablet king in 2012
50. Product Roundup: Sensors/Transducers
54. Tales from the Cube: Lightning strikes
9
Теги:
