Пользователей: 587
Аналоги: 232. Даташиты: 246. Инструкции: 3. Новости: 15. Остальное: 21. Профиль пользователя: 25. Расчёты: 3. Форум: 41. Чат: 1.
Гостей: 585
Раздел: Circuit Cellar
Circuit Cellar №278 2013
Сообщений MACTEP 08.09.2013 15:10:00 (Просмотров: 5616)
Название: Circuit Cellar №278 2013
Автор: коллектив
Издательство: Circuit Cellar
Год: 2013
Месяц:  SEPTEMBER
Страниц: 84
Формат: DjVu
Язык: английский
"Circuit Cellar" - популярный зарубежный журнал по электронным компонентам и схемотехнике для любителей и специалистов любого уровня
SEPTEMBER 2013 • ISSUE 278
1■ CC COMMUNITY
08 : CC WORLD
10 : QUESTIONS & ANSWERS Electronics Entrepreneur
Engineer Jack Ganssle on projects, consulting, and the next big thing
14  : MEMBER PROFILE
Systems engineer Dean Boman (Chandler, AZ)
■ NDUSTRY & ENTERPRISE
15  : NEW PRODUCTS
23  : CLIENT PROFILE
NetBurner (San Diego, CA)
2■ FEATURES
24  : Rubik's Cube-Solving Robot
By Nelson Epp
Microcontroller-based robot uses a 52-move algorithm
to solve a Rubik's Cube puzzle
32 : Raspberry Pi I/O Board (Part 2)
ISO-Pi Circuit Description and Firmware
By Brian Millier
Build an I/O board to interface with a Raspberry Pi
42 : Experiments in Developmental Robotics (Part 1)
Artificial and Evolving Neural Networks
By Walter 0. Krawec
Robot learning with an evolving neural network
■ COLUMNS
348 : THE CONSUMMATE ENGINEER Battery Basics (Part 1)
Battery Types
By George Novacek
Tips on comparing battery characteristics and
performance
54 : ABOVE THE GROUND PLANE Pulsed LED Characterization
By Ed Nisley
Explore LED features with a stress tester and optical
output detector
60 : GREEN COMPUTING
Energy-Efficient Cooling Strategies for Servers
Analyze and Control Leakage and Fan Power
By Ayse Coskun
Minimize processor overcooling by designing practica
control systems
64 : FROM THE BENCH
Serial Displays Save Resources (Part 3)
BMP Files
By Jeff Bachiochi
The BMP file format and working efficiently with
graphic icon data
■ TESTS & CHALLENGES
72  : CROSSWORD
73  : TEST YOUR EQ
■ TECH THE FUTURE
80 : Electronics Beyond Silicon
By Jeremy Ward and Oana Jerchescu Silicon's limits fuel research into flexible, organic electronics—from smart bandages and rollable displays to disposable single-use sensors
