Пользователей: 575
Аналоги: 275. Даташиты: 200. Инструкции: 6. Магазин: 1. Новости: 17. Остальное: 7. Производители: 1. Профиль пользователя: 34. Теги: 1. Форум: 33.
Гостей: 573
Раздел: Nuts And Volts
Nuts and Volts №1 2013
Сообщений MACTEP 25.12.2012 23:50:00 (Просмотров: 7225)
Название: Nuts and Volts
Издательство: nutsvolts.com
Год: 2013
Месяц: January
Страниц: 84
Формат: PDF
Качество: Отличное
Язык: English
Nuts and Volts - популярный журнал по электронным компонентам и схемотехнике для любителей и специалистов любого уровня.
NUTS and VOLTSProjects & Features
32 The Sirius Metronome for the
      Serious Musician
      One of the most important tools any musician needs
      is a metronome. The circuit described here
      sports a number of impressive features that even
      more expensive commercial units can’t provide.
      ■ By Thomas Henry
40 Build an Inverting DC-DC Converter
      Ever need negative voltage when all you can get is
      positive? This voltage mirror device will give you -V
      out when you put +V in, and works over a range
      of voltages without adjustment.
      ■ By Jim Stewart
46 King Tut’s Pyramid Gravimeter
      Use this novel assembly to determine the
      gravity of most any situation.
      ■ By Ron Newton
Columns
10 TechKnowledgey 2013
      Events, Advances, and News
      Some of this month’s tidbits include a
      supercomputer that hits 20 petaflops/s,
      the next-gen of the iMac family, and how to
      record your entire life effortlessly.
14 Smiley’s Workshop
      Programming • Hardware • Projects
      The Arduino Proto Shield Alarm Clock.
24 Q & A
      Advanced Techniques for Design Engineers
      Questions about a voltage converter, a trigger
      LED from a distributor, and a bench top power
      supply are answered, plus a digital pressure
      gauge is revisited this time around.
52 The Design Cycle
      I’m in an LMX-ISM-242 State of Mind.
60 The Spin Zone
      Adventures In Propeller Programming
      New Life for an Old LCD.
72 Near Space
      Approaching the Final Frontier
      Using the Nearspace Simple Flight Computer.
Departments
08 DEVELOPING PERSPECTIVES
09 READER FEEDBACK
28 NEW PRODUCTS
31 SHOWCASE
67 ELECTRO-NET
68 NV WEBSTORE
71 CLASSIFIEDS
80 TECH FORUM
81 AD INDEX
