Пользователей: 309
Аналоги: 73. Видео: 1. Даташиты: 73. Новости: 15. Остальное: 4. Программы: 3. Производители: 2. Профиль пользователя: 27. Теги: 1. Форум: 110.
Гостей: 307
Раздел: Nuts And Volts
Nuts and Volts №1 2014
Сообщений MACTEP 22.12.2013 14:00:00 (Просмотров: 6022)
Название: Nuts and Volts
Издательство: nutsvolts.com
Год: 2014
Месяц: Jаnuаrу
Страниц: 84
Формат: DjVu
Качество: Хорошее
Язык: English
Nuts and Volts - популярный журнал по электронным компонентам и схемотехнике для любителей и специалистов любого уровня.
January 2014
28 Build a PIC-Based Remote Temperature Sensor
     You can never have too many remote sensors, right?This circuit lets you set
     up a homemade weather station to monitor the most popular of all parameters:
     temperature.
     By Ryan Clarke
NUTS and VOLTS34 The (Nearly] Universal Process Monitor
     While the circuit described here is specifically for showing system parameters
     in an electric truck conversion, you can utilize it as a process monitor and
     display for analog and pulsed signals in a variety of applications.
     ■ By Daniel Gravatt
38 All About Clocks for PICs
     Taking the time to understand how clock options really work in a microcontroller
     will make implementing them that much easier.
     ■ By Thomas Henry
44 MakerPlot—The DIY Software Kit Part 4
     Learn how to plot both analog and digital data from the Arduino Uno, then see
     how to log that data and play it back for greater analysis.
     ■ By John Gavlik and Martin Hebel
Columns
NUTS and VOLTS08 TechKnowledgey2014
      Events, Advances, and News
      Read about a transistor that learns, secure wireless access, the
      Smellophone, plus some other cool stuff.
12 The Spin Zone
      Adventures in Propeller Programming
      Shifty Business.
      Sometimes the simple thed-and-true solutions are overlooked because of
      the ever-increasing sophistication of microcontrollers. Case in point: shift
      registers.
20 Q&A
      Reader Questions Answered Here
     Questions on LED drivers, remote control, and video and power over cable
      are answered.
NUTS and VOLTS52  Smiley s Workshop
      Programming • Hardware • Projects
      The Arduino Classroom.
      Even though the Internet is flowing with tutorials on how to use the Arduino
      microcontroller, sometimes it's nice to have everything put together into an
      easy-to-follow introductory course. That's what we've done here.
62  Near Space
      Approaching the Final Frontier
      A New Airframe Design for Near Spacecraft — Part 2.
      Building a new airframe is only part of creating a near spacecraft. There are
      things like post burst chaos that have to be considered.
67  The Design Cycle
      Advanced Techniques for Design Engineers
      Utilizing Embedded Web Development.
      Remember drilling that slightly off-center toggle switch mounting hole for your
      project's front panel then have it be a bit too large? Those days are long gone.
      Trade in that drill and dull set of metal bits for some silicon versions that
      machine  a perfect virtual front panel every time.
Departments
06 DEVELOPING PERSPECTIVES
      Up Close & Personal
07 READER FEEDBACK
24 NEW PRODUCTS
27 SHOWCASE
65 ELECTRO-NET
74 NV WEBSTORE
77 CLASSIFIEDS
78 TECH FORUM
81 AD INDEX
