Пользователей: 94
Аналоги: 30. Даташиты: 18. Инструкции: 1. Новости: 10. Остальное: 4. Производители: 3. Профиль пользователя: 3. Форум: 24. Чат: 1.
Гостей: 91
Раздел: Nuts And Volts
Nuts and Volts №12 2013
Сообщений MACTEP 28.11.2013 20:00:00 (Просмотров: 4868)
Название: Nuts and Volts
Издательство: nutsvolts.com
Год: 2013
Месяц: December
Страниц: 84
Формат: DjVu
Качество: Хорошее
Язык: English
Nuts and Volts - популярный журнал по электронным компонентам и схемотехнике для любителей и специалистов любого уровня.
December 2013
NUTS and VOLTS28 Construction of a Low Budget 180 MHz RF
      Sweep Generator
       Sweep generators have a lot of uses in the design, prototyping, and
       troubleshooting of amps, filters, and other circuitry. I wanted one that could
       speed up these tasks by presenting several parameters at the same
       time.This is the unit I came up with.
       ■ By Robert Reed
38 Build a Wireless Silent Alarm Warning System
      This is an inexpensive transmitter /receiver system you can build in one night
      that will let you know if something is amiss.
      ■ By Roger Secura
NUTS and VOLTS42 My Christmas Can light Dimmer
      Since I wasn't going to be able to replace my incandescent icicle lights with
      new LED versions, I needed a way to extend their life.
      ■  By Frank Muratora
46 The Good, the Bad, and the HexBright
      Follow Christian's journey with Kickstarter for his Arduino-based flashlight
      that finished in the tup 10 most funded projects.
      ■ By Christian Carlberg
52 MakerPlot—The DIY Software Kit Part3
      This time, learn how to connect your microcontroller to the software to plot
      a single channel of analog data. Plus, see how To scale raw ADC data into
      corresponding voltage levels so you don't have to do math inside your micro.
      ■ By John Gavlik and Martin Hebel
Columns
NUTS and VOLTS08 TechKnowledgey 2013
      Events, Advances, and News
      Light-emitting pasta, Intel + Arduino = Galileo, a DC meter suitable for battery
      monitoring, and an IEEE conference in Vegas are just some of the highlights
      from this month's selection.
12 PICAKE Primer
     Sharpening Your Tools of Creativity
     The Ins and Outs of Python Programming.
     Start off with a few Python experiments with digital inputs on the Raspberry Pi,
     then implement a Cylon Eye project to continue our quest of interfacing the
     PICAXE with a Pi.
20 Q&A
     Reader Questions Answered Here
     Bandpass filters, 12 volt control, and NiCad battery chargers are asked about and answered this time.
58  Smiley s Workshop
Programming • Hardware • Projects
Arduino Handheld Prototyper — Part 6.
It's a wrap with data togging. Learn how to upload sensor data directly to a PC — first, via the serial port and then using an SD card.
68 Open Communication
The Latest in Networking and Wireless Technologies
Wireless Watches Will Win the Wearable Wars.
Even though cell phones have encroached on the time-keeping arena, you may want to rethink the wtistwatch concept.
Departments
06 DEVELOPING PERSPECTIVES
      No Your Fater's LEDs
07 READER FEEDBACK
24 NEW PRODUCTS
26 SHOWCASE
66 ELECTRO-NET
74 NV WEBSTORE
77 CLASSIFIEDS
78 TECH FORUM
80 AD INDEX
