Пользователей: 154
Аналоги: 59. Даташиты: 71. Инструкции: 1. Новости: 4. Остальное: 4. Профиль пользователя: 3. Теги: 1. Форум: 11.
Гостей: 152
Раздел: Nuts And Volts
Nuts and Volts №3 2014
Сообщений MACTEP 02.03.2014 1:40:00 (Просмотров: 6116)
Название: Nuts and Volts
Издательство: nutsvolts.com
Год: 2014
Месяц: March
Страниц: 84
Формат: DjVu
Качество: Хорошее
Язык: English
Nuts and Volts - популярный журнал по электронным компонентам и схемотехнике для любителей и специалистов любого уровня.
March 2014
NUTS and VOLTS22 Build an Inexpensive 12 volt/ 12 amp Modern Digital Solar Charge Controller
This reader-requested solar controller for charging 12 volt lead-acid batteries is very simple to build and will help keep your batteries in tip-topped off shape.
■ By Ron Newton
28 A Multi-Stage High Speed Input Monitor
This neat little device will help you make those close calls in high speed competitive events.
■ By John Mastromoro
33 A Unique LED Clock
Just when you thought there were no more cool electronic clocks to build, this Arduino-controlled version showed up.
■ By Craig A. Lindley
40 Breaking the Arduino Speed Limit
Just how fast can you push the Arduino platform before it releases that magic smoke? Very fast, actually.
■ By Bob Davis
48 MakerPlot—The DIY Software Kit... Part 6
See how to have MakerPlot send info to your micro of choice to control the firmware's setpoint using a 'slider'.
■ By John Gavlik and Martin Hebel
Columns
08 TechKnowledgey 2014
Events, Advances, and News
Topics to read about this time include squeezing out leakage; faster, cheaper SSD; a real crock; plus some other interesting stuff.
12 The Spin Zone
Adventures in Propeller Programming
More Shifty Business.
Expanding quadrature encoder inputs using the 74x165.
NUTS and VOLTS54 Smiley s Workshop
Programming • Hardware • Projects
The Arduino Classroom.
Arduino 101/Chapter 3: How an Arduino
Program Works.
Get introduced to the basic concepts of an Arduino program, then use those concepts to keep counts and times so you can blink some LEDs in a pattern.
62 Near Space
Approaching the Final Frontier
A New Airframe Design for Near
Spacecraft — Part 3.
Securing the more expensive internals of a near spacecraft to the airframe is the final — and perhaps most important — step in finishing the new design.
67 The Design Cycle
Advanced Techniques for Design Engineers
Setting Up Linux With Bones is a Piece of Pi.
I'm a Microchip PIC kind of guy. However, when it comes to Linux, almost any flavor will do. The Raspberry Pi and BeagleBone Black are getting lots of press. So, instead of deciding whether to bake a Pi or walk the Dog, we are going to do both. In this installment of Design Cycle, we will make the crust and put a leash on the Dog.
Departments
06 DEVELOPING PERSPECTIVES
    Know Your Basics
07 READER FEEDBACK
18 NEW PRODUCTS
21 SHOWCASE
66 ELECTRO-NET
74 NV WEBSTORE
77 CLASSIFIEDS
78 TECH FORUM
81 AD INDEX
