Пользователей: 977
Аналоги: 557. Видео: 1. Даташиты: 337. Инструкции: 5. Магазин: 1. Новости: 29. Остальное: 8. Партнёры: 1. Программы: 2. Производители: 1. Профиль пользователя: 20. Расчёты: 2. Теги: 3. Форум: 10.
Гостей: 975
Раздел: EDN
EDN 03 2012г
Сообщений MACTEP 04.03.2012 15:40:00 (Просмотров: 6364)
Издательство: Reed Elsevier Properties Inc.
Год выпуска: 2012
Номер: 3
Дата выпуска: 2 Feb
Число страниц: 52
Формат: PDF
Качество: отличное
Язык: Английский
VOICE OF THE ENGINEER
In number:
08. EDN online: Join the conversation; Content; Engineering Community
10. EDN.comment: Kodak's travails provide multiple lessons
12. Handheld scopes' VGA displays reveal waveform details under all lighting conditions
13. Microchip targets active-current reduction in PIC24F expansion
14. Resistive touchscreens add multitouch capabilities
14. Osram enters pilot production with GaN-on-silicon high-power LEDs
15.  Floating surge-stopper 1С clamps 500V and more, allows cool-down period
15. Single-chip, nine-axis INU targets consumer devices
16. HTML5 platform for infotainment systems debuts at CES
16. Batteries last longer, thanks to monitoring device
17. Piccolo development kit targets LED lighting and communications
17. Buck-boost converter does 2.7 to 40V input/output, provides bump-free transitions
19. Signal Integrity: Parallel resonance
20. Exploiting subthreshold MOSFET behavior in analog applications
24. Power MOSFETs continue to evolve, thanks to wafer thinning and innovative packaging
30. Balancing GBWP and quiescent current for dissipation optimization
35. Small-signal bandwidth in a Big Bandwidth era
39. Stable pulse generator uses matched transistors in a current mirror
42. Implement an audio-frequency tilt-equalizer filter
45. Circuit provides 70 dB of AGC
46. Supply Chain: Intel muscles into smartphones, tablets; Inventory adjusts to slow market
48. Product Roundup: Passives
50. Tales from the Cube: The cows do the tipping, or how the West was won
Теги:
EDN
