Пользователей: 560
Аналоги: 342. Даташиты: 184. Инструкции: 3. Новости: 13. Остальное: 4. Производители: 1. Профиль пользователя: 2. Форум: 10. Чат: 1.
Гостей: 557
Раздел: EDN
EDN 16 2012г
Сообщений MACTEP 24.10.2012 15:00:00 (Просмотров: 6641)
Издательство: Reed Elsevier Properties Inc.
Год выпуска: 2012
Номер: 16
Дата выпуска: October
Число страниц: 104
Формат: PDF
Качество: отличное
Язык: Английский
contents
09 EDN online: Join the conversation; Content; Engineering Community
10 EDN.comment: Could this take the $10 million Tricorder X Prize?
12 Tektronix adds lower-priced mixed-domain scopes
14 8-bit USB microcontrollers slash power, form factor
14 Linear LED driver targets low-current lighting systems
15 DIY is kick-started for the masses
16 Voices: Avnet's Roy Vallee: Design careers are marathons, not sprints
18 Signal Integrity: Nickel matters
20 Baker's Best: Collecting light power: voltaic or conductive?
22 Teardown: PillCam exposes your innards
24 Mechatronics in Design: Modeling the MEMS gyroscope
27 Squeezing the most from battery cells with a switched-mode pump
46 Common inter-IC digital interfaces for audio data transfer
50 Booster circuit enables reliable solenoid operation
51 Injection-lock a Wien-bridge oscillator
56 Convert your smartphone into a pedometer and tracking device
57 Photo meter assesses ambient light
58 Postprocessing converts Spice to RF analyzer
60 Supply Chain: Integrating innovation into the supply chain; iPhone 5 to spur record Q4 Apple phone shipments
63 Product Roundup: Power Sources
66 Tales from the Cube: But I only need the switch!
Теги:
EDN
