Пользователей: 150
Аналоги: 67. Даташиты: 47. Инструкции: 3. Новости: 5. Остальное: 1. Программы: 1. Производители: 2. Профиль пользователя: 6. Форум: 18.
Гостей: 148
Раздел: Elektor
Elektor №6 2013г
Сообщений MACTEP 09.06.2013 20:00:00 (Просмотров: 4942)
Год: 2013
Месяц: Июнь
Номер: 6
Формат:DjVu
Язык: Английский
Elektor - популярный зарубежный журнал по электронике и схемотехнике
CONTENT
Elektor Community
8  Elektor World
     • The Tube in the Lunchbox
     • Getting Control
• DesignSpark
10 Day 1 — Make it just the way you want
     Getting started with DesignSpark PCB and configure it to your likings.
     This tutorial shows you how to set up your personal preferences in this
     latest release of PCB design software.
13 The Cat's Whisker
     Crystal Diode FRIHO D.R.P
Projects
14 Wi-Fi Controller Board
     Control your home from your mobile phone with this universal Wi-Fi
     controller board. We show how to set the color of an RGB LED strip,
     but you can use it for a variety of other applications.
22 Recycle your ATX Power Supply
     This ATX bench top power supply adapter board converts any standard
     ATX computer power supply into a convenient supply for breadboarding
     and general workbench use,
26 Off to the EF Library!
     ElektorUsing Elektor's 'Embedded Firmware Library', code for an embedded project
     can be generated swiftly without the need to know which type of interface
     will be used. This tool helps both beginners and old hands.
34 Lost Model Finder
     Build this radio detection finder and never lose your radio controlled plane
     again. Simply switch on the receiver and it points you straight to the crash
     location.
40 Lithium-ion Battery Recycling Made Easy
     Re-using Lithium-ion batteries can be tricky. Often they are charged inside
     the equipment, so there isn't a separate charger available. Luckily,
     a charger for used (or new) Li-ion cells is fairly easy to build.
44 Taming the Beast (5)
     ElektorAlthough FPGA applications can be designed using schematic diagrams
     with logic symbols, in practice this is usually done with a hardware
     description language. An advantage of the latter approach is that complex
     functions are often easier to express in algorithms than in schematics.
     Accordingly, in this installment we guide you through the process of
     programming an FPGA application.
54 From BASIC to Python (2)
     This second installment elaborates on graph plotting and Fourier synthesis.
     And without much effort we setup a graphical user interface,
62 Beefing up DAC Resolution
     Improve the resolution of ordinary, cheap digital/analog converters by using
     Elektorthe output of one as a programmable voltage reference for the others.
Labs
64 LCR Meter Shootout
     A quick comparison between Elektor's 500 ppm LCR Meter and two other
     LCR measurement devices
• Industry
66 New Performance Requirements for Resistors
     Today's aircrafts are increasingly fuel efficient and need to conform to
     anti-pollution regulations. The humble resistor can be helpful, provided
     Elektorsome of its key specifications are given close consideration.
70 News & New Products
     A selection of news items received from the electronics industry, labs
     and organizations.
Magazine
74 Retronics: Konrad Zuse's Zl through Z4 and beyond
     ElektorEver since the earliest days of mathematics and logical thought, people
     have tried to find ways to simplify the repetitive work involved. This article
     takes a tour of Konrad Zuse's impressive contributions to the development
     of the computer. Series Editor: Jan Buiting.
78 Hexadoku
     Elektor's monthly puzzle with an electronics touch.
79 Gerard's Columns: In the Clouds
     A column or two from our columnist Gerard Fonte,
82 Next Month in Elektor
     A sneak preview of articles on the Elektor publication schedule.
Теги:
