Пользователей: 245
Аналоги: 81. Даташиты: 72. Инструкции: 4. Новости: 7. Обзор: 1. Остальное: 52. Программы: 1. Производители: 3. Профиль пользователя: 7. Торрент: 1. Форум: 15. Чат: 1.
Гостей: 242
Раздел: Elektor
Elektor №11 2013г
Сообщений MACTEP 12.11.2013 18:50:00 (Просмотров: 5440)
Год: 2013
Месяц: Ноябрь
Номер: 11
Страниц: 84
Формат:DjVu
Язык: Английский
Elektor - популярный зарубежный журнал по электронике и схемотехнике
Contents
Elektor 11 Community
8  Elektor World
    • Let Your Brain Do the Thinking
    • All Smiles
    • The Internet of Things' Launching Point
    • That Sounds Good!
Projects
10 CAN Tester
     The circuit described here has all the features required for conducting
     various experiments and tests on a CAN bus. In addition there is the option
     Elektorof connecting the tester to an existing CAN bus to monitor the data or to
     track down faults.
18 Elektor Linux Board: New and Improved!
     The compact and low-cost Elektor Embedded Linux board has been
     available to buy for around a year and a half now. Along with its
     accompanying series of articles it offers even beginners access to the world
     of embedded Linux. It is now time for us to update the board based on
     feedback from the user community. To begin with let's add LAN and RTC.
22 Important Update to the Elektor 500 ppm LCR Meter
     Here we correct two shortcomings liable to interfere with proper operation of
     the instrument: occasional hang-ups and issues with the Trim actions.
Elektor26 Multichannel
Temperature Logger
     This project allows you to log up to six temperature readings over a period of
     time, complete with time stamps, all written to a .csv file stored on an SD
     card for processing on a PC. Local control is also available in the form of an
     LCD and a keypad.
Elektor32 USB Thermometer
     When you need to hook up some electronics to an RS-232-less computer,
     the USB port looks like the only option. The computer however needs a
     corresponding software driver. Here we describe an elegant patch around
     this problem.
42 Bidirectional
     eStereo Input Selector
     Following a recent appeal made in the magazine calling on our readers to
     send us their own circuit designs—if possible simple and preferably in fields
     that receive less coverage in Elektor, like audio, for example—we received
     this suggestion which meets the two main criteria: uncomplicated and
     intended for processing sound signals.
46 LED Lighting for Model Buildings
     This small module has been designed to individually control five LEDs used
     to illuminate model buildings. The control signal is sent over a single wire
     from a PC's RS232 serial port. The design allows for up to 250 modules to
     be controlled by a single PC, that's almost enough for a small town!
DesignSpark
Elektor38 DesignSpark Tip & Tricks, Day #5: generating PCB
     manufacturing files
     Today we will generate the Gerber files and BOM information for the design
     we laid out last time. DesignSpark has excellent support for generating
     these types of files once it's been configured properly.
Labs
50 .Labs Tips & Tricks
     This month we present a selection of projects posted on Elektor.Labs and
     looking for a helping hand to reach the finish line. Can you cheer and/or
     assist?
52 Standards for Coding
     eOften a lot of time and energy is spent on designing an elegant,
     well-thought-out and robust circuit. Today, the brains of many of those
     circuits is a microcontroller that needs software to function. Is it
     unreasonable then to expect a well-designed, properly written program to
     make such a quality circuit work? Apparently it is. Let's talk software quality.
58 Keep The Pins Afloat
     Forget to tick a few boxes and your entire FPGA project fails to work, as our
     lab workers found out the hard way.
60 PCB Prototyper Master Class
     Here's a how-to on an advanced application of the Elektor PCB Prototyper
     milling machine.
Tech The Future
Elektor68  Forze VI:
      A Hydrogen-Powered Racecar
     The Forze VI weighs just under 2,000 lbs., achieves a top speed of 138 mph,
     and accelerates from 0 to 60 mph in 4 seconds. The heart of the racecar is
     the fuel cell system.
• Industry
64 News & New Products
     A selection of news items received from the electronics industry,
     labs and organizations.
Magazine
70 Retronics: Freystedt's Audio-Frequency Spectrometer
     The story of finding and restoring the extremely rare 1935 Siemens
     Spectrometer, a landmark in electro-acoustic measurement.
     ElektorSeries Editor: Jan Buiting.
76 Hexadoku
     Elektor's monthly puzzle.
77 Gerard's Columns: Conscientious Objector
     A column or two from our columnist Gerard Fonte.
82 Next Month in Elektor
Теги:
