Пользователей: 228
Аналоги: 63. Даташиты: 52. Инструкции: 2. Новости: 19. Остальное: 56. Профиль пользователя: 21. Советы: 1. Форум: 13. Чат: 1.
Гостей: 225
Раздел: EDN
EDN №6 2013г
Сообщений MACTEP 11.06.2013 20:20:00 (Просмотров: 4319)
Издательство: Reed Elsevier Properties Inc.
Год выпуска: 2013
Номер: 6
Дата выпуска: June
Число страниц: 46
Формат: DjVu
Качество: отличное
Язык: Английский
CONTENTS
June 2013
pulse
12 Wi-Fi board combines Arduino with Linux for easy M2M use
14 Inexpensive 3-D printer kit creates plastic components
16 Now playing: the world’s smallest movie (made with atoms)
18 Graphics chip recognizes nearby pedestrians and bicycles
18 Invisibility cloak hides objects from radio waves
19 Ohm’s Law iPhone app helps engineers back-solve electrical power calculations
20 Voices: NI’s Eric Starkloff: inspired by engineering ingenuity
EDN
DEPARTMENTS & COLUMNS
9 EDN online: Join the conversation; Content; Engineering community
10 EDN.comment: Cognitive radio arrives, all by itself!
22 Signal Integrity: Seek inspiration
24 Baker’s Best: Don’t be fooled by your amplifier’s bandwidth
26 Teardown: The engineer’s mind
28 Mechatronics in Design: Managing complexity and reducing risk
60 Supply Chain: What business are you in? Semiconductor suppliers have largest inventory in PC chain
63 Product Roundup: Tools
66 Tales from the Cube: Blame the programmer!
Теги:
